Results 1 to 9 of 9
    Mar 2011
    Paris, France
    Hello
    For some reason, I can't get ffmpeg to resize a 848x480 video (H264/AAC) to 640x480.
    I tried the following commands, but both end up with the same original size, although VLC says the output video is 640x480:
    ffmpeg.exe -report -i input.mp4 -shortest -c:v libx264 -vf scale=640:480 -pix_fmt yuv420p -strict experimental -c:a aac -ab 128k -ar 48000 -strict -2 -f mp4 output.mp4
    ffmpeg.exe -report -i input.mp4 -shortest -c:v libx264 -s 640x480 -pix_fmt yuv420p -strict experimental -c:a aac -ab 128k -ar 48000 -strict -2 -f mp4 output.mp4
    Any idea why?
    Thank you.
    What do you identity the video frame size with? ffmpeg, Mediainfo?
    Mar 2011
    Paris, France
    I just play the output video in VLC and check Tools > Codec Information.
    Are "-vf scale=640:480" or "-s 640x480" the right switches to change the size of a video, or should I use something else?
  4. I tried both your command lines and they both worked. A random 1280x720 video was resized to 640x480. It was properly flagged to play back at the original 16:9 aspect ratio. Are you looking to squish the video so it plays 4:3 instead of 16:9?
    Mar 2011
    Paris, France
    Thanks for the feedback.
    I was just trying to convert a video so that it would go from 848x480 to a more standard 640x480. I'll investigate further.
  6. 848x480 is a ~16:9 aspect ratio. 640x480 is a 4:3 aspect ratio. The issue isn't what frame size you want, ffmpeg is giving you that, it's what aspect ratio you want the video displayed at.
    Mar 2011
    Paris, France
    Thanks for the info. I'll read up about changing aspect ratio.
  8. If you want the resulting video to display 4:3 add "-aspect 4:3". For example:
    ffmpeg.exe -report -i input.mp4 -shortest -c:v libx264 -vf scale=640:480 -aspect 4:3 -pix_fmt yuv420p -strict experimental -c:a aac -ab 128k -ar 48000 -strict -2 -f mp4 output.mp4
    Mar 2011
    Paris, France
    Thank you.
